Cel code P0141 how to fix it? help
okay so i only have one o2 sensor in my header and just replaced this one today and the code is still on
i dont have the SECOND o2 sensor at all
all i got its just a pipe goin all the way to the muffler
does any one know how to fix this ?
and what do to for this code to be gone ?
plz help
should i get a test pipe and just install the second o2 sensor would it help ?
plz help
Technical Hero
Re: Cel code P0141 how to fix it? help
plz help
plz help
You just answered your own question, you'll need to get an O2 simulator or convert to OBD1 or use a catalytic converter with a "sparkplug fouler" with a second O2. And no it'll still throw the code with an O2 sensor in the test pipe.
^ What he said. However, you will get a new code if you put in the B1S2 sensor, and just a test pipe. A P0420 (Catalyst system efficiency below threshold)
i got 2000 si and the previous owner of the car removed the second o2 sensor completely so theres nothing
i only got the 1st sensor and i just replaced last night.
Yep you will still get a code. As I mentioned before, it will be a P0420 catalyst system efficiency below threshold code.
den dawg u got 2 juss say *** it dawg.
On a more serious note, everyone has already listed the ways to fix the issue. If you could read everyone's posts then that'd help you out.
If you put a catalytic converter and a second o2 on the car the code will go away.
Put a test pipe and a defouler and it'll go away. or convert to obd1 and it'll go away.
Can't put it any simpler.
98savage
06-15-2007 09:35 PM
98savage
05-15-2007 10:33 PM
