6 PSI boost with 9.2:1 compression ratio
hey i got a 93 civic ex non-vtec and i was just wondering if i would run into any problems running 3-6psi of boost into the stock internals?
Re: 6 PSI boost with 9.2:1 compression ratio (Threshld1)
Blown motor within 6months to a year. But then again since you are only going to run 3-6 psi it shouldn't be too bad. Just make sure the engine is getting more fuel.
Either way your motor is gonna get worked.
BTW EX's have SOHC Vtec motors, unless your's was swapped?
Re: 6 PSI boost with 9.2:1 compression ratio (Mr. Shin)
youll be coo. just get fuel and you can go 9 lbs. my boy sohc vtec was pushing 10lbs with all fuel and ignition upgrades.
Re: 6 PSI boost with 9.2:1 compression ratio (Mista Bone)
unless its unmarked and every site ive seen is wrong... as far as i know its not vtec and yes its an SOHC
http://www.vyger.net/~kent/pics/car/engine.jpg
thats a shot of my engine
Re: 6 PSI boost with 9.2:1 compression ratio (PatrickEwing)
do you know what a vtec solenoid is? Tell us your engine code. It should be d16z6, those 93's didn't come with vtec valve covers, so that's probably what you're thinking.
On a stupider note:
sunroof = vtec
almost all the time.
On a stupider note:
sunroof = vtec
You have a VTEC engine for sure. The 92-93 Civic Si and Ex did not have the word VTEC on the valve cover. The 94-95 Civic Si and Ex do have the "VTEC" word on the valve cover. You sir are the proud owner of a D16Z6 SOHC VTEC engine.
Re: 6 PSI boost with 9.2:1 compression ratio (vivid02)
by god... your right.... big fat sticker with barcode on the side says D16Z6! i guess that explains why all my 125hp of "power" is above 5k rpms....
Re: 6 PSI boost with 9.2:1 compression ratio (nfiedler3)
lol...maybe you should wait a bit and learn about your car before you boost it
Re: 6 PSI boost with 9.2:1 compression ratio (W.ZeroB18C1T)
also if you wanna know if its vtec or not look at where the spark wires go. if at the top of the valve cover its non vtec and if its at the bottom its vtec or just look for a vtec solinoid. just thought you might wanna know . also correction on the 94-95 vtec on valve cover only 95 comes that way. 92-94 shouldnt have it. i have a 95 cpe ex that had it and a 94 si HB that didnt.
LOL first one ever heard off not knowing if vtec or not !!?!?
good luck with the turbo !! but try som headers and filter first !! and suspention and breaks !! THEN turbo !! and learn on the way !!!
Re: 6 PSI boost with 9.2:1 compression ratio (Zeus Zore)
HAHAHA thank you for posting that... notice how she is not wearing any shoes and is sitting where there is a support bar and she didnt scratch the paint at all. and the reason i ask about the turbo is more of just getting some ideas and wondering if its even possible. my friend has a 90 celica alltrack turbo and he got a whole new 3-gst (i believe) front clip for $1200 for it so he just said for fun he would sell me his old turbo for $100 and im just looking into all the stuff i would need to make it work. and being i would have to make my own custom exhaust header for it or pay out the *** i dont think its gonna happen unless you people have any better ideas. just toying with ideas while i have no money and trying to learn as much as i can before i do have the money so i dont break anything
about the VTEC thing i just never saw anywhere that it was actually VTEC and i believe that my Chiltons doesnt have anything about it either but ill check. thanks for the tips and bearing with my young stupid inexperianced ***, gotta learn somehow though right?
On the part of learning, it is better to learn as much as you can from other peoples mistakes and experiences....unless you have money tree in your backyard or something and an extra car for a daily driver, it's no fun learning by blowing up your motor
Good luck...
i understand you !! but look a turbo celica can not be compered 2 a N/a 1.6 honda !! i notist that there where no shoes !!
and good luck with building you caR !!
may as well let u know some of the other goodies ull need to think about that ll go along with booting ur car..befor u know it ull need an upgrade d clutch and brakes
