Adding an ACT clutch and lightened flywheel make car quicker
Will adding a ACT-heavy duty/organic cluctch with a lightended flywheel make you car faster??? [Deciding if I sould install it into my car because I just have it sitting around and don't know if it will really help]
Civic EX 96'
Civic EX 96'
Re: Adding an ACT clutch and lightened flywheel make car quicker (civEX)
if you have it laying around, why wouldn't you put it on??
the flywheel if help your car rev quicker by having less weight and restriction to spin the flywheel, thus puttin' the power down to the wheels..the clutch will allow you to transfer that power through the gears, or something
D Tranny Guru
Depends on the launch and what tires you are using.
My old D15 on slicks was .15 SLOWER with a 12.2 lb flwheel compared to a stock 18 unit.
WHY?????
The puny D15 NEEDED the heavier to launch the car. Once car is moving, then the lighter flywheel will be a little faster.
Now onto my Z6 NA setup on slicks, I was .2 tenths FASTER with same lightweight flywheel and used Centerforce DF disc over the stock unit.
WHY?????
Vtecme92
03-14-2006 06:20 AM
