Help! About to drop the b18b in
Ok so I just wanna make sure Im right ....Im swappin this in my 95 sedan ...B18B I will need drivers side integ mount and rear mount ...and it will bolt on right ? Thats all im un sure about thanks (Devin17)
Re: Help! About to drop the b18b in (jcstites)
i just did that swap 2 days ago in my 92vx. i would get all the integra mounts if you can. i didnt get the rear one with my swap. i used integra ones for all but the rear and the lower drivers side mount.
Passenger side tranny mount is the same (civic and teg).
Use the teg mount for the driver side upper (next to shock tower)
The other mounts should be the integra ones, but retain the civic rubber mounts that bolt to the subframe.
Good Luck.
Good Luck.
rasinhell
19
07-29-2005 09:03 PM
