ITR sway Bars on Ek.
Guest
Posts: n/a
I wanna put ITR rear sway bar and front sway bar on my Ek. what do i need if i have stock suspension. Also what do i need if i put 5lug ITR/CTR suspension on it. and want to put the ITR sway bars. I have GSR sway bars sittin but are they the same as ITR.
Re: ITR sway Bars on Ek. (StreetRacnGsR)
Here is my suspension: https://honda-tech.com/zerothread?id=408156
Beaks kit is a must: http://beaksproducts.com/srk-ek.html
ITR rear sway from: http://www.acuraautomotiveparts.org/
Would suggest leaving front sway stock.
You can also use your stock LCA's (or buy mine! See link in sig!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR »</TD></TR><TR><TD CLASS="quote">How much for your LCA's I have a suspension techniques Integra rear kit that was 290 for it. with everything but beaks kit will that work also? thanks</TD></TR></TABLE>
LCA's link: https://honda-tech.com/zerothread?id=508345
It will work with any kind of kit. It has the sway bar link holes just like the OEM arms.
Re: ITR sway Bars on Ek. (mrlegoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">Here is my suspension: https://honda-tech.com/zerothread?id=408156
You can also use your stock LCA's (or buy mine! See link in sig!)</TD></TR></TABLE>
Very helpful, but Beaks sells their kit w/ a brand new ITR rear sway (from Acura) to save you time.
Also, if he has an "EK" he must have a hatch meaning he has no front sway. So, I'd say he has an OPTION of getting a 96-00 Civic EX front sway (LCAs also) , 99-00 Civic SI front sway (also LCAs/dampening forks), or just run with no front sway. It all depends on what he wants to do with his car. This is my dream suspension if you wanted to know...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddie HatchBlack »</TD></TR><TR><TD CLASS="quote">26mm SI front sway (you need LCAs and dampening forks)
22mm USDM ITR rear sway w/ beaks kit [ http://www.beaksproducts.com ] (you also need SI endlinks)
Mugen front/rear upper strut bars
Spoon front/rear lower tie bars
Tein's (Any kind will suit MY driving style)
Bridgestone Potenza Pole-Position S-03s (I think tires are important)
SRR LCA's (If I ever break mine)</TD></TR></TABLE>
Re: ITR sway Bars on Ek. (Eddie HatchBlack)
Also, if he has an "EK" he must have a hatch meaning he has no front sway. </TD></TR></TABLE>oh yeah
The Stabilizer Endlink's are like 65$ EACH
The ITR bar is like 55$
(+ shipping and handling)
In the end I think you only save like 10-15$ buying the individual pieces rather than just buying the whole kit from Beaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">oh yeah
In the end I think you only save like 10-15$ buying the individual pieces rather than just buying the whole kit from Beaks. </TD></TR></TABLE>
True about saving, 10-15, but won't you lose that anyways with shipping? Not trying to be rude or anything, just pointing it out.
I've always been wondering why everybody says that the Beaks kit is a must when you add an ITR rear swaybar to a 96-00 Civic, but both the ITR and CTR come with that swaybar and the swaybars never rip out of those cars. Does the USDM Civic have a weaker subframe than a CTR or something? If it doesn't, why does the USDM Civic "require" a Beaks kit w/ a 22 mm swaybar and the CTR/ITR doesn't?
I hope somebody has the answer to my question.
Re: ITR sway Bars on Ek. (EricUSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC »</TD></TR><TR><TD CLASS="quote">I've always been wondering why everybody says that the Beaks kit is a must when you add an ITR rear swaybar to a 96-00 Civic, but both the ITR and CTR come with that swaybar and the swaybars never rip out of those cars. Does the USDM Civic have a weaker subframe than a CTR or something? If it doesn't, why does the USDM Civic "require" a Beaks kit w/ a 22 mm swaybar and the CTR/ITR doesn't?
I hope somebody has the answer to my question. </TD></TR></TABLE>
Yes, the CTR has a completely different and stronger subframe.
The ITR is reinforced.
Re: ITR sway Bars on Ek. (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">
The ITR is reinforced.</TD></TR></TABLE>
The mounting points are flat, yours are indented.
Looks kinda like this:
edit- Whats wrong with the bold function?
