When does VTEC engage on a 97 EX???
Old 05-20-2003, 07:48 PM
SiR-DC2's Avatar
Default When does VTEC engage on a 97 EX???
Also what ECU is it, I thought VTEC on a sohc was at 5000, mine is at 5700 and my revlimit is at 7500, my ecu is a P2P. Anythoughts? Is this correct? Just curious, I would search but rather hear other opinions. Thanks.
SiR-DC2 is offline
Old 05-20-2003, 08:02 PM
Default Re: When does VTEC engage on a 97 EX??? (SiR-DC2)
On mine it comes on right around 5600-5700. With my ebay cai you can really hear the switch over.
However, on 96-00 ex the redline is around 6800 rpm. The earlier ex's (92-95) redline was 7200 rpm
How are u shifting at 7500 rpm on the obd-2 computer?
willyboyK20 is offline
Old 05-20-2003, 08:50 PM
RyanEJ8's Avatar
For the P2P 5500rpm=VTEC, 6800=Redline, Fuel cut-off is a little bit above redline around 7000rpm. The stock tach is a little off.
For the P28 same VTEC, redline at 7200rpm and the fuel cut-off is a couple hundred rpm above that I am assuming. It seems to go a little farther than my P2P, but I haven't hit the rev limiter yet.
RyanEJ8 is offline
Old 05-20-2003, 09:06 PM
Default Re: When does VTEC engage on a 97 EX??? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">For the P2P 5500rpm=VTEC, 6800=Redline, Fuel cut-off is a little bit above redline around 7000rpm. The stock tach is a little off.
For the P28 same VTEC, redline at 7200rpm and the fuel cut-off is a couple hundred rpm above that I am assuming. It seems to go a little farther than my P2P, but I haven't hit the rev limiter yet.</TD></TR></TABLE>
i always heard that on the p28 vtec kicks in at 4500? however, i've never driven in one, so i wouldn't know from experience. you're right about the p2p. according to the stock tach, my cutoff is at 7200.
vladd is offline
Old 05-20-2003, 09:14 PM
RyanEJ8's Avatar
Default Re: When does VTEC engage on a 97 EX??? (civicdxtyper)
Yeah I have also heard the P28 VTEC is at 4800rpm before, but have more commonly heard 5500, but I guess more commonly doesn't necessarily mean its right.
RyanEJ8 is offline
Old 05-20-2003, 09:18 PM
eg6turbo's Avatar
i have a p28 obd1 and it comes in at 4900 dyno proven...it could be 4800 but around there for sure it could activate at 4800 and i see the gain on the dyno graph as 4900...i dunno i say 4900 tho...
eg6turbo is offline
Old 05-20-2003, 09:23 PM
RyanEJ8's Avatar
Default Re: When does VTEC engage on a 97 EX??? (eg6turbo)
I wonder if the earlier engagement of VTEC on the P28 could actually hurt performance then?
RyanEJ8 is offline
Old 05-20-2003, 09:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if the earlier engagement of VTEC on the P28 could actually hurt performance then?</TD></TR></TABLE>
i'm sure the vtec point is tuned to the engine, honda should know enough about their engines to know when to set the vtec engagement.
vladd is offline
Old 05-20-2003, 09:30 PM
RyanEJ8's Avatar
Yes, but I am using a P28 with a D16Y8, which would normally use a P2P, so it is not the same engine.
RyanEJ8 is offline
Old 05-20-2003, 09:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but I am using a P28 with a D16Y8, which would normally use a P2P, so it is not the same engine.
oh ya, i forgot about that. i thought you were just talking about a stock d16z6 with a p28.
vladd is offline
Old 05-20-2003, 09:38 PM
RyanEJ8's Avatar
Yeah, I'm wondering, maybe when I put in my Hondata, I should set VTEC back to 5500rpm, if it is indeed at 4800rpm.
RyanEJ8 is offline
Old 05-21-2003, 07:56 AM
SiR-DC2's Avatar
That's f'n nuts. I know how inaccurate tachs can be but at say 5600 I can hear VTEC, BUT on my dash, it goes all the way to 7500 on the dash, I understand the ecu is right and the tach MUST be wrong but damn, being so accurate at 6000 rpm and off at 7500 makes no sense to me. Oh well...
VTEC SOHC 5600
Revlimit 7200
Redline 6800
SiR-DC2 is offline
moonman
10-08-2012 06:57 PM
eg6sittingon57cs
Honda Civic (2001 - 2005)
09-02-2007 10:46 AM
aj99si
01-05-2006 10:29 PM
808State
06-21-2005 08:08 AM
johnny hatchback
06-04-2004 02:47 PM
Quick Reply: When does VTEC engage on a 97 EX???
  • Ask a Question
Question Title:
Description:
