OBD-2 to OBD-1 / Service connector problem
I recently converted to OBD-1 and I'm throwing a code. I tried to jump the service connector, but it isn't working. Since everything in the car is OBD-2 except for the ecu will the service connector trick work? I need a way to pull this code. Any suggestions? TIA
Re: OBD-2 to OBD-1 / Service connector problem (Tony Starks)
It should work, unless there is a misswire in your conversion harness.
Re: OBD-2 to OBD-1 / Service connector problem (tonyXcom)
I need to do the same thing. 95 ls motor in 98 civic. I am using my civic Ex wiring harness, so I dont have a service connector do I? I see a brown plug that is taped up right before the firewall, but it hase like 10 row of pins? anyone?
Re: OBD-2 to OBD-1 / Service connector problem (civcexcoupeblack)
Yes you still have a service connector. Look above where your old ecu was mounted. It will be inside of lime green rubber boot. At least its lime green in my car.
Mine looks to be more of a Green Apple color.
Re: OBD-2 to OBD-1 / Service connector problem (junglerunna02)
Yes it should blink, but mine isn't. I hope its not a miswire in the harness. I payed $150 for that thing.
Tehknein
01-02-2015 02:30 AM
agratise
05-24-2005 06:17 AM
