a little help
a little help
just did mini me swap. y7-y8 obdII. my car reads KS and i readline at 6000 and i don't have any vtec. pressure switch and silenoid are good, they have been tested. any help fixing this thing. also should it redline higher since i have a gode drag cam. aem cai, dc header, cat-back, aem cam gear. please help still one slow 96 dx
Modified by sockminime at 6:23 AM 5/22/2003
Re: a little help (sockminime)
If you clarify what your problem is, and try to speak correct english, then maybe someone on here can help you. I have no idea what your asking??
Re: a little help (Ricey McRicerton)
96 civic mini me swap. my y7 block has no knock sensor so my p2p computer reads that as a code, but my redline is still stuck on 6000 rpm. once i install a knock sensor will this make the vtec work and change the redline. i was told that because i have a cam that my redline would be even higher even though it is a sohc. hop this make more since this car is pissing me the **** off please help.
sypher909
11-04-2008 06:38 PM
gato5254
07-29-2005 12:24 PM
