calling all axel experts!
ok. will 92-98 civic w/ abs axels work in my 94 cx w/ z6 and 98 ex tranny?
i bought some outter hubs for a 97 civic ex. had same # of teeth as the cx.so i dont think the cx -> dx -> ex matters as far as splines...
but what is the difference in the driver side axel from civics with abs compared to non abs. thanks
no difference in axle dimensions.....the only difference in appearance is that the ABS axle has a "ring tooth gear" on the hub end......
in other words, it will work
Re: (SpoonFedHatch)
ok sweet. the outter axel spline count is 26 teeth. the inner is? inside the EX tranny. where the teeth or splines are ... in a triangle location .. there are 3 smooth spots on each side. like one tooth was filed down. but in a perfect triangle. obviously not broken. are the axels supposed to match that design where they enter the tranny? thanks alot. i am finally getting this swap worked out!
and one more thing. will the axel seal from my 94 cx 5spd tranny work for a 98 ex 5spd tranny? i have the cx sitting around, no time during the day to get to honda for a seal...but one needs to be replaced on the ex. lmk if they are swapable. thanks
SL!M
11-02-2005 07:17 AM
comptechgsr
12-14-2003 03:28 AM
xXx Justin xXx
28
05-21-2003 06:46 AM
