h22/ek harness
Only EK harnesses work in EK chassis. You can modify your harness to work, no matter what trim level or motor you have. Of course if you have a stock VTEC engine you have an advantage already.
Re: h22/ek harness (www.soundbomber.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.soundbomber.com »</TD></TR><TR><TD CLASS="quote">if you have a 98, get a 96-98 ex harness, if you have a 99+ get a civic si harness</TD></TR></TABLE>
There you go dude! You will still have to probably lengthen a few branches or whatever to make sure it all reaches comfortably, and I think the H22A has IAB on it like the GSR intake manifold, so you'd need to add a wire the the ecu plug and a ground wire on the engine side but that's about it. Depending on what ecu you run with you may be able to ignore some sensors too.
Re: h22/ek harness (klungemonger)
You have exact answer on what wires need to be added to and the color? I have a 97 obd2 h22 motor and a 96 dx hatch and a 97 ex harness.
Re: h22/ek harness (ekblacknight)
hey man spend some time reading this it should answer all your questions.
https://honda-tech.com/zerothread?id=650329
