help on going turbo?
i have a 96 coupe with the d16y8. i have a t3 garrett turbo with a hf exhaust manifold.. any of u guys know the cheapest way to get the kit together...where should i get the piping, intercooler, bov,etc...keep in mind i want to go the cheapest route....and how much boost should i be running on stock internals??
for the piping... search diy pipings... you can make a complete intercooler piping by cutting u-bend pipes. try buying used bovs... for the intercooler, try http://www.johnnyracecar.com they're pretty cheap there. hope that helped
Re: (BOOSTEDebp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDebp »</TD></TR><TR><TD CLASS="quote">ive found some stuff for pretty cheap just off the classifieds on here</TD></TR></TABLE>
true, but if you look at the amount of scammers out there (even on H-T) I dont suggest buying something from a private party. Definately go through a company. You'll spend a bit more, but at least you'll get your parts you paid for!
Re: help on going turbo? (oneforce)
go to http://www.homemadeturbo.com and ask around to see if anyone can make you an adapter plate for your turbo/mani combo. i'm POSITIVE you'll find someone there that can.
as for pipes, http://www.jcwhitney.com has piping available. other than that, hit up ebay.
intercooler: http://www.johnnyracecar.com as someone mentioned above. they're nice/cheap intercoolers that can handle about 350 whp (more than you'll ever need)
fuel management: depending on what you want to run, search the classifieds on https://honda-tech.com http://www.turbod16.com http://www.homemadeturbo.com and you'll be able to find something that'll suit you, whether it be an fmu ( ), afc hack and injectors or uberdata
TopEndUSA
11-16-2009 03:58 PM
JDMCRX
Welding / Fabrication
06-19-2007 08:29 PM
