problems with shifter
ever since i did my swap my shifter has been realy loose. i used the right shift linkage. i can shift into gear but when i'm in gear my shifter can rock side to side like its in neutral. any sugestions?
Re: problems with shifter (jbscivichb92)
http://importnut.net/shifter.htm. try this, install instructions and tips.
on the shifter there is a boot that holds the ball part in place. if you brake that it moves around cause it is not set like it used to be. i broke a few of them racing so i ended up having to get an b&m shifter to fix it.. i can get the part # for the shifter, but check the boot that the shifter sits in and see if you boke the plastic peaces in side it..
good luck
good luck
DOUBLExDEUCEx22
07-08-2009 02:12 PM
BAZ
07-29-2003 09:29 PM
STHPERFORMANCE
07-06-2003 07:28 PM
