EK: Auto To Manual + B16 = what tranny mount to use?
As the title says. Theres not bracket on the chasis so should i order one and weld it on?
Jeff-
Jeff-
Where is the missing bracket you are talking about? The chassis only has rubber-isolator type mounts that are bolted in, not plain brackets that require welding. I'll check the parts page online and see if I can find out more of what you mean.
There are 5 chassis rubber mounts on both the EK B16 Si model and the EK D16 automatic model. To my knowledge you can leave all the chassis rubber parts in as long as you use the 99-00 Si engine mount brackets. There is no welding required though. Check these out, one is the auto D16, the other is the B16 EK:
http://slhondaparts.com/browse...=true
Modified by klungemonger at 3:56 PM 11/19/2004
toofast4you1989
09-15-2009 03:03 PM
rollercosta123
10-09-2005 05:22 PM
