ECU
ECU
Ive heard alot about p28 ecu's. I understand there from a sohc vtec car (si hatch, ex coupe) and you can chip them and run it with a b16a2 swap. but can someone explain to me the positives in using this ecu, ive never heard a good explanation, just to do it. Thanks alot.
Re: ECU (matthevelli)
OBDI
no knock sensor
can be chipped or converted to Hondata.
Chipping is not recommended unless you are running a 13:1 compression B series with stupidly aggressive sticks.
no knock sensor
Re: ECU (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">OBDI
no knock sensor
Chipping is not recommended unless you are running a 13:1 compression B series with stupidly aggressive sticks.</TD></TR></TABLE>
"Chipping" is a misunderstood and misused term. You would need to install an external ROM in the P28 programmed with P30 code to run the B16 properly.
no knock sensor
RTW DC2R
04-04-2006 09:42 PM
streetracerof06
10
12-29-2005 06:14 PM
arielmalespin
05-31-2005 03:45 PM
