Valve Adjustment - Cost?
think i may need a valve adjustment on my 93 civic lx, anyone know about how much a shop would charge to do it? a friend of mine and i did it before but i dont wanna rip the valve cover off and mess with it unless it's gonna cost some god aweful amount of $, thanks.
HT Order of Merit
Re: Valve Adjustment - Cost? (Black93LX)
Its easy enough to do yourself if you have the proper tool. A shop shouldnt charge you that much, it takes maybe a half hour MAX.
cute little bastard
got my B16 done last night by my shop. it is fairly easy if you have the right tools. unfortunatly my shop didnt have the tool that makes it easier so it took a while. charged me $60 + i bought him a Whopper Jr.
Re: Valve Adjustment - Cost? (alotawatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">What would the tool to make it easier be ?............A unique wrench to reach/turn the crank ?</TD></TR></TABLE>
all u have to do is roll the car back in forth to get it in the right spot, trust me ive done it
Re: Valve Adjustment - Cost? (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">
all u have to do is roll the car back in forth to get it in the right spot, trust me ive done it </TD></TR></TABLE>
Why do you need to roll the car back and forth when you can just turn the crank bolt ?
Re: Valve Adjustment - Cost? (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">Why do you need to roll the car back and forth when you can just turn the crank bolt ?</TD></TR></TABLE>
i unno dont have tools but have the room
cute little bastard
No its a valve adjustment tool. Its like a 10mm wrench bent 90 degrees with a screwdriver on top that way the screw doesnt move when you are tightening the locking nuts. It's just a quicker/accurate way to do it. And I had to get a special feeler gauge that was bent about 90 degrees to fit under the lobes.
Re: Valve Adjustment - Cost? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">No its a valve adjustment tool. Its like a 10mm wrench bent 90 degrees with a screwdriver on top that way the screw doesnt move when you are tightening the locking nuts. It's just a quicker/accurate way to do it. And I had to get a special feeler gauge that was bent about 90 degrees to fit under the lobes. </TD></TR></TABLE>
Correct, you dont need one though. Proper Feeler Guages, 10mm wrench and a flat head screwdriver and you are set also. Well, and knowing the proper sequence/timing marks.
depending on the vehicle you have you may need to bend your feeler guages to fit in the intake valves.
My dealer (Honda) charges 65.00 Labor, then you have to add whatever a valve cover cost.
Re: Valve Adjustment - Cost? (Calculator)
You've done it before - why NOT do it again??
The hardest part for me (D16Y7) was getting the valve cover back on while holding the valve cover gasket in place (with the correct application of HondaBond) and moving the throttle cable outta the way.
For my D-series, you def do not need the special tool. The special tool makes doing B-series a whole lot easier.
Someone actually made a DIY version - they just hammered a wrench onto the socket - voila', all done and you can fit the flathead screwdriver through the socket where the ratchet drive square would normally fit into.
