What's the difference between the GSR and ITR Engine?
What makes the ITR engine have the extra 25 more horsepower compared to the GSR engine. Is it a cam? Is it higher compression? Is it both, or something else? It could be a whole combination of things. Cause im thinking that it could be cheaper to just buy the GSR and put some cams in it and a few other things to make it have just as much horsepower. I wanna put the GSR engine in my civic. If you have some answers please post.
Thanks
Thanks
Re: What's the difference between the GSR and ITR Engine? (Preludes'R'Us)
Its more than just a few things that separate a gsr swap from an itr. Crank,pistons,cams,head,IM,ecu, tranny are a few things I can think off right now
However you can achieve the same goals with both engines.
Man, thanks guys. To me it looks like you'll be spending the same amount of money to make the gsr just like the ITR. I guess the ITR would be a better idea, i got the money, so do you think I'm better off buying the ITR, or buying the GSR and fixing that up?
Re: What's the difference between the GSR and ITR Engine? (sohcvtec1995)
if you learn to search you could find a lot has been covered
thru a search on H-T for "GSR ITR COMPARISON" (make sure to click on) "archive topics" I found a thread with this informative link
http://www.vtec.net/articles/v...=3428
<FONT SIZE="6">please LEARN TO SEARCH</FONT>
searching "GSR ITR Difference" archive topics
you will find several topics like this
https://honda-tech.com/zerothread?id=786203 (among 57 other results)
the key is not to limit yourself too much by your choice of words
Former Moderator
Look dickface I already posted all the infop you needed in that locked H22A vs. B18C5 engine topic.
<FONT SIZE="7">GIVE IT UP ALREADY! YOU CANNOT MAKE UP THE 25WHP DIFFERENCE AND THE LSD, BETTER GEARED TRANNY WITH JUST THE $1,500.00 YOU SAVE BY GETTING THE GS-R SWAP! COMPARE THE PRICES OF THE COMPLETE SWAPS FROM H MOTORS ONLINE, IMPORT AUTO SALVAGE, ETC. - IT'S ONLY $1,500.00!</FONT>
teg92
36
05-30-2004 08:59 PM
