Intake Manifold HELP!!
Can i swap an Ex intake manifold onto my DX motor??? I dont know because the throttle bodies are switched. the Dx which is the D16Y7 faces up and the ex which i think is the D16y8 faces normally to the side??
Please Help!!
For sale: 2 fosgate 12" subs in box and 600watt kenwood amp...make offer
For sale: 1999 EK hatch black, salvage, runs great very little damage $2000
Please Help!!
1 Post
Re: Intake Manifold HELP!! (tuner6r)
yes you can the manifold will bolt right up to the motor, your intake stuff however will not. if you are going to be getting a short ram or something like that or all of the stock ex tubing then you will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuner6r »</TD></TR><TR><TD CLASS="quote">Can i swap an Ex intake manifold onto my DX motor??? I dont know because the throttle bodies are switched. the Dx which is the D16Y7 faces up and the ex which i think is the D16y8 faces normally to the side??
Please Help!!
For sale: 1999 EK hatch black, salvage, runs great very little damage $2000 </TD></TR></TABLE>
The intake manifold will bolt right up. You will have to reuse the Y-7 throttle body, with a Y-8 throttle rotor.
Please Help!!
Re: Intake Manifold HELP!! (L.D.S. Construction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L.D.S. Construction »</TD></TR><TR><TD CLASS="quote">
The intake manifold will bolt right up. You will have to reuse the Y-7 throttle body, with a Y-8 throttle rotor. </TD></TR></TABLE>
Why cant i use the Y8 throttle body????
Why cant i use the Y8 throttle body????</TD></TR></TABLE>
Because your ECU is set up for a three wire IACV, and with the EX throttle body you would have to use a two wire. If you get a manifold off of a 5 speed car, you will also have to make a block off plate for the Ex Iacv.
Or you could swap the head and ECU and do whats called a "mini-me" swap.
Curbow_USMC
21
01-30-2009 02:50 PM
JDMLRG209
12-23-2008 11:54 PM
CivicEKCP
06-27-2003 02:56 AM
