timing belt bracket mount block attachment thing that i need <--what is the name and where can i
hey i have a 94 si hatch and i'm installing this 94 gsr, the gsr was in a ek so it has this bracket thing with only two holes, i was told that i need the one with three holes, where do i buy it and what is the name of the thing
thanks
thanks
1 Post
Re: timing belt bracket mount block attachment thing that i need <--what is the name and where ca
u need one that has 2 bolt and 1 hole or just 2 bolt like the one on the trasmision
ig ot what you are looking for. the 2 studs that are about 1 inch apart and then theres a hole for a bolt to go down into and screw into the mount.
pm me for it
pm me for it
its called a motor mount get it for a 94 gsr integraand get the bracket too thats the thing with 3 holes
how much do they cost, i dont need the round mount with rubber on each side that attaches to the chassis, i already have it, i just need that part in the actual pic, and the 2 thick *** bolts that stick up through the holes
how much should i spend on that???????
bump because i still need a name of that metal bracket thing that attaches to the block
i already have the mount, the part that i need has no rubber on it, it just has two long studs sticking out
What is that called SPECIFICALLY???????and how much should i spend on one????
thanks
thanks
som3on3_10
08-13-2004 12:12 AM
