idle bounces with new intake
does anyone know why my idle goes from 650-1200 couple of times after a rev or aftering going then stepping on the clutch. this started happening after i installed the fake j intake on my cx. any tips would be great
Modified by komat at 5:47 PM 1/21/2005
o god forbid 650 - 900! ur motor is gonna die. well no its not. but if that 250rpm bounce scares you then try settings ur throttle cable different or cleaning ur iavc. other than that theres no visible problem
Re: (MoonRacer13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">It's not normal, and you probably have a vacuum leak to take care of.</TD></TR></TABLE>
Maybe a crack in the tube? Is that what you guys are talking about. If not then it would seem strange to have a vacuum leak only after installing an intake and not having a leak before. That is wierd though.
-Shane
-Shane
Re: (nighttrain33)
tube as in the intake tube or the breather tube?
it also starts like 5min after i start up the engine
then i rev it once
the idle will go from 650-1200
i checked the breather line it seem to be fine
i will take out the intake tomorrow to see if theres any crack on it but that shouldnt be cuaseing hte problem.
Modified by komat at 8:18 PM 1/21/2005
then i rev it once
