spoon sports transmission drain plug measure?
Re: spoon sports transmission drain plug measure? (BEEZERone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEEZERone »</TD></TR><TR><TD CLASS="quote">ok just measured it its 1.2 centimeters </TD></TR></TABLE>
ok check again and see if that comes to 12mm (i want to make sure) and i appreciate your time. thanks
Re: spoon sports transmission drain plug measure? (cxSHOE)
i have one out in my tranny so i couldn't tell ya but hey love them both why do ask the measurement?
Re: spoon sports transmission drain plug measure? (OrangeCiviC251)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 »</TD></TR><TR><TD CLASS="quote">i have one out in my tranny so i couldn't tell ya but hey love them both why do ask the measurement?</TD></TR></TABLE>
im going to have a magnet made for me and i need measurements. i know i can just buy a spoon set and be done. but i can have a custom one made with a stronger magnet put on for about $15 bucks. just experimenting thats all.
Re: spoon sports transmission drain plug measure? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">There's 2.5 cm in an inch and 25mm = an inch, so that would be right about 12mm.</TD></TR></TABLE>
i know the conversion is correct. i want to make sure his 1.2cm is correct... im not sure if he measured by mm then converted to cm to make it easier for me or if he only had a cm ruler and came up with that measurement.
in other words 12mm is exactly 1.2 cm so maybe he measured in mm and then converted it to cm ... ill have to see what he says.
just woundering i just got the spoon drain plugs theres one with a really long magnet that one is for the oil pan right.
and the short one is for the tranny
Re: spoon sports transmission drain plug measure? (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">just woundering i just got the spoon drain plugs theres one with a really long magnet that one is for the oil pan right.
and the short one is for the tranny</TD></TR></TABLE>
correct.. measure the transmission one so i can confirm its 12mm from base to the top of magnet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">i see thanks
its 21mm from base to top of magnet
magnet is 6mm long</TD></TR></TABLE>
and let me know if you can measure the transmission one so i can lock this thread look at photo above to see what i need measured
ahh never mind i saw your post above at 21mm great thanks for your help.. i appreciate your time
hayabusa160,
I've pm'd you incase you don't see this post.
Need to know how magnetic your bolts are compare to the one's I've brought.
saer
06-08-2005 08:56 AM
