Fitment of shifter -- b-series swap
Will a stock 2000 DX shifter work with a b16 swapped 96 hatchback? I broke my shortshifter and Just need a quick replacement.
Thanks guys
Thanks guys
Re: Fitment of shifter -- b-series swap (jdmhello)
Yes it will , but you will either have to shim or wider the part where the shifter bolt to the assembly. It's been a while so I forget if the civic was wider or smaller.
1 Post
Re: Fitment of shifter -- b-series swap (lsvtecracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecracer »</TD></TR><TR><TD CLASS="quote">Yes it will , but you will either have to shim or wider the part where the shifter bolt to the assembly. It's been a while so I forget if the civic was wider or smaller. </TD></TR></TABLE>
the D-series shifter is narrower than the B-series linkage.some shims will fix it.
Chris
Chris
Re: Fitment of shifter -- b-series swap (TeamNextGenChris)
i had my d series shifter in for a few weeks with no shims at all. it would kinda rub the linkages together, but it was functional
1 Post
Re: Fitment of shifter -- b-series swap (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">i had my d series shifter in for a few weeks with no shims at all. it would kinda rub the linkages together, but it was functional</TD></TR></TABLE>
you can "squish" the sides of the B-series linkage against the D-series shifter without shims if you tighten the bolt enough,but there is about a 1/2" gap if you don't.this will lead to sloppy/impossible shifting if not corrected.
Chris
Chris
mr. robot-o
06-27-2008 06:45 AM
KFBhonda
10
11-29-2004 04:44 PM
