b16 going into my EG, what sensor?
Ive got this b16a1 going into my EG. What sensor is this? Looks like it was broken off or somthing...
Also what is that green sensor next to the oil filter. It has two metal prongs coming out of it. the EG harness that I am going to be using only has one metal prong coming out.
Re: b16 going into my EG, what sensor? (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">knock sensor.</TD></TR></TABLE>
that right
that right
Re: b16 going into my EG, what sensor? (HATCHingMN)
So is it broken or somthing?... Where can I get an replacement and part #? How much does it cost. LMK
Also what is the green sensor next to the oil filter with the two prong thingys.
Re: b16 going into my EG, what sensor? (iNCU3US)
yes, it's broken. you can go to the classifies, or the honda dealer. it's will cost 0\bucu of money. 70-80 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNCU3US »</TD></TR><TR><TD CLASS="quote">So is it broken or somthing?... Where can I get an replacement and part #? How much does it cost. LMK
Also what is the green sensor next to the oil filter with the two prong thingys.</TD></TR></TABLE>
No really broken just not require using it.
what ecu are you using?? p28 ecu from an Si or Ex dont look for knock sensor!!
Better Picture,
Both #1 and #3 are for the cooling and condenser fans. The first one reads the oil temp(#1), at 226 degrees F, the sensor gives the fan ground. Now, the oil temp sensor only comes on cars with a/c. The Engine Coolant Temp. (ECT) (#3) reads the coolant temp. At 194 degrees F, it gives the fan ground. And #2 is a low oil pressure light for the Oil light in the gauge cluster.
knock sensor..look like this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNCU3US »</TD></TR><TR><TD CLASS="quote">Ok so lemme get this right. I will be using a p28 from an EX. I wont be using that knock sensor?</TD></TR></TABLE>
correct
correct
