Am I missing something?? Help Please
Speedometer does not work and odometer does not work... I have an EG6 with a B18B swap. It looks like i'm missing a plug to something... Please help.
Thanks In Advance
Thanks In Advance
Re: Am I missing something?? Help Please (HardKor3)
go to passenger side of engine bay look at the back part of the tranny there should be a sensor coming out should be plug in to the harness if not, if find the plug and click it on
I checked and looks like its there on the tranny... does this plug go somewhere? Someone else did the swap so i don't know much about the setup
everyone is correct, if your speed and odo is not working it has to be the speed sensor, it located in the back of your transmission on the top side, there should be a black plastic object sticking out about a good 2inch or so...cant miss it
can you get a closer shot of the plug?
Re: Am I missing something?? Help Please (JDMFreak)
It looks to me like your car originally came with a firewall mounted map sensor, while your new motor has the map mounted ontop of the throttle body.
On a firewall mounted map sensor, it would sit exactly where that plug is.
Are you throwing any check engine lights?
Re: Am I missing something?? Help Please (Slopoke)
I've gotten use to driving my car that I won't throw a CEL. But usually when I do, its because I let off the gas in gear and let the RPMs drop below 2K and it will throw a code. Once i restart the car... it goes away... heard it was an O2 sensor problem
Wouldn't he throw a code if the VSS is not plugged in? Just a thought. I know he said he throws a code sometimes, but he should throw a VSS code all of the time if it wasn't plugged in.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardKor3 »</TD></TR><TR><TD CLASS="quote">I've gotten use to driving my car that I won't throw a CEL. But usually when I do, its because I let off the gas in gear and let the RPMs drop below 2K and it will throw a code. Once i restart the car... it goes away... heard it was an O2 sensor problem</TD></TR></TABLE>
check the code that its throwing, if ur speedo isnt working, im betting its the speed sensor code its throwing, sounds like it cause my cousin had the same prob in his G2 teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardKor3 »</TD></TR><TR><TD CLASS="quote">I have an EG6 </TD></TR></TABLE> No you dont!!
Re: Am I missing something?? Help Please (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote"> No you dont!!</TD></TR></TABLE>
Thats seriously all you could contribute to the thread?
LMAO
LMAO
1 Post
looks like the connecotr to the VSS in that pic.as said above,look at the tranny to see if a plug is plugged in there to the sensor.if it is,either wiring or VSS is bad.
MAP sensor is plugged in,so it's not a matter of the firewall mounted MAP sensor.it's plug is also different from the VSS plug anyway.
from my experience,the ECU will not always throw a VSS code immediately if it is unplugged.check your ECU to see what codes it has stored.
Chris
Chris
Re: Am I missing something?? Help Please (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">looks like the connecotr to the VSS in that pic.as said above,look at the tranny to see if a plug is plugged in there to the sensor.if it is,either wiring or VSS is bad.
Chris</TD></TR></TABLE>
He said the vss is plugged in.
Check your codes.
Let us know what color the wires are on the mystery connector and we can find out what it is.
Check your codes.
as stated before the plug you have pictured is for a firewall mounted MAP. did the speedo work before the swap? You might want to check your fuses and maybe try another cluster if you have one available. It should also be throwing a VSS code if it is not working. Another to check about that plug is it is easy to confuse with the TPS on the back of the TB. The map and TPS interchange as far as being able to plug into each other.
Sorry If I was no help.
Re: Am I missing something?? Help Please (flat-blk-HB)
i dunno if the speedo worked before... i got the car in this condition... swap with no speedo... =/ i'll see if i can get another cluster... and yes they are all interchangeable... i have about 3 plugs right now and i tryed any combination i can find... but they seem to choke my engine when i start it... right now with it like this... it works fine... no other plug missing... looks like
Pull the VSS plug and check to see if there is any corrosion on the pins. Alot of times salt and water can get in plug do to age and climate. If there is clean and put Dielectric grease in the connector to keep oxygen out and stop the corrosion. If this is not the case then you may need a new speed sensor,or your speedo head-(in your cluster) is bad.
Luke G.
08-22-2009 09:53 AM
