Throttle sticking after D16Y8 Intake Mani swap...
I swapped the D16y8 intake mani on my Y7. now when I stop and lights and stuff my throttle sticks some times (it's hard to press the pedal down). I have to tap it pretty good to get it to go.
It feels like the throttle cable is binding somewhere... Do I need the Y8 throttle cable?
by the way I did get the intake mani bracket for the throttle cable but the rest of the cable brackets are my Y7 brackets...
Re: Throttle sticking after D16Y8 Intake Mani swap... (Jon V)
im using my y7 cable on a z6 mini with no probs maybe you need to clean the throttle body
Re: Throttle sticking after D16Y8 Intake Mani swap... (nub)
hey its your throttle cable just adjust it so it doenst stick, with the two nuts you know.... if needed more explain just PM me
Re: Throttle sticking after D16Y8 Intake Mani swap... (IAmTheRealKevron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron »</TD></TR><TR><TD CLASS="quote">hey its your throttle cable just adjust it so it doenst stick, with the two nuts you know.... if needed more explain just PM me</TD></TR></TABLE>
just tighten it up? so it holds the throttle body open a little more?
my throttle has been sticking too but i didnt do anything to it. if you come across a solution throw it up
Re: Throttle sticking after D16Y8 Intake Mani swap... (bleh)
I had the problem too when I did the swap. I kept readjusting the throttle cable tension and it was gone in a while.
Re: Throttle sticking after D16Y8 Intake Mani swap... (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Tighten the cable.</TD></TR></TABLE>
Just make sure there is no slack in it. You can also try brushing the point where the butterfly pivots on the throttle body to be sure that's not the culprit.
Re: Throttle sticking after D16Y8 Intake Mani swap... (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">You can also try brushing the point where the butterfly pivots on the throttle body to be sure that's not the culprit.</TD></TR></TABLE>like with a toothbrush on the inside of the tb?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleh »</TD></TR><TR><TD CLASS="quote">like with a toothbrush on the inside of the tb?</TD></TR></TABLE>
Yeah, except on the outside.
ekx4
06-01-2007 10:38 AM
Wazup
02-21-2006 11:26 AM
