Front rotor size 96-00...
Okay, I know the 96-00 EX models have 10.3" front rotors. This is my dillema... My 1997 Acura 1.6EL should have the same 10.3" front rotors/calipers/knuckle as the 96-00 Civic EX because it's essentially the same car. I bought a steering knuckle from the pick and pull from a 1997 Civic EX, and the caliper mounting holes didn't line up. Are my EL's front rotors larger than the EX's 10.3? No ABS by the way...
Re: Front rotor size 96-00... (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">Okay, I know the 96-00 EX models have 10.3" front rotors. This is my dillema... My 1997 Acura 1.6EL should have the same 10.3" front rotors/calipers/knuckle as the 96-00 Civic EX because it's essentially the same car. I bought a steering knuckle from the pick and pull from a 1997 Civic EX, and the caliper mounting holes didn't line up. Are my EL's front rotors larger than the EX's 10.3? No ABS by the way...</TD></TR></TABLE>
in canada, i think you'll need EX-R front brakes.
USDM -> CDM
LX -> EX
EX Sedan -> EX-R Sedan
EX Coupe -> Si
Si -> SiR
** edit: oops. not sure if the top-of-the-line EK sedan was the EX, EXR, OR Si....
USDM -> CDM
LX -> EX
EX Coupe -> Si
Si -> SiR
Re: Front rotor size 96-00... (dantastic)
There aren't any EX-R civics... there are EX-R Accords, but not civics. Maybe there are different trim levels of the EX or something where they came with 9.5" and 10.3" brakes... I'm not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinahondaboy »</TD></TR><TR><TD CLASS="quote">while your at it get some power slots </TD></TR></TABLE>
This thread isn't about changing the brakes, it's about the steering knuckle and rotor sizes between different models. Besides which, I wouldn't buy "power slots" anyways, I'm replacing the factory rotors with Brembo blanks in the spring. Brembo blanks > power slots IMO.
blackstar
05-10-2005 03:56 PM
