VTEC Oil Pressure Sensor Question....
New User
Are the VTEC Pressure Sensors different through the different versions of B16? All the VTEC motors I have seen use a GREEN sensor mounted on the VTEC actuator assembly. But the B16A2 that I have doesn't have this sensor, and doesn't have threads or an opening where the sensor belongs. Are the B16A2's different in this aspect? I'll be using an OBD1 setup...
Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk »</TD></TR><TR><TD CLASS="quote">I've heard some JDM motors don't use this, and that you run that wire into the Vtec soleniod wire.</TD></TR></TABLE>
I just ran the a wire from the ECU pressure switch location to ground. I would still like to get a pressure switch as an extra precaution though.
