trouble with the str throttle body
i have a 2000 civic si and i just bought a STR throttle body and i still have the stock intake manifold for right now, but now my car idles at 2500 rpm i already changed the tps sensor and the map sensor and i adjusted the screw on the throttle body and tightened up the cable. I am at a loss now, does anyone else know what might be the problem.
thanks,
wamp
thanks,
wamp
Re: trouble with the str throttle body (jwamp316)
check the TB gasket.
Run the car, spray some carb cleaner around it in light amounts and see if the rpms don't raise a little.....if it does, take the TB off and see where the gasket is wet.
You may be able to just put some gasket sealer on it let it dry per the directions and see if that fixes your idle problems.
Re: trouble with the str throttle body (Spade)
bump for my friend since he no longer has access to the internet...
he replaced the str gasget with the stock gasget and still is having the same problem
the cables and the butterfly have complete room to open and close like they should so there is no issue with that and i personally can't think of a reason why it would be doing this.
any help is appreciated i'll will be comunicating with jwamp over the phone updating him with anything you guys might think would help or resolve the issue
Re: trouble with the str throttle body (punku10)
might want to inspect the tb if its getting a little stuck open at idle and double check
the cable linkage incase you might of overtighten to where it gives high idle upon engine start.
Re: (1whitedc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1whitedc2 »</TD></TR><TR><TD CLASS="quote">i am pretty sure there's some sort of vacuum leak on that STR TB, my friend had one, same thing...i recommend not to use that STR TB, it's a POS...</TD></TR></TABLE>
i had a 68mm str tb..i didnt have a vac leak......
Re: (GOLDBERG)
i run a 68mm str tb as well. no problems here. try starting with the throttle cable off... that'll eliminate the possibility of the cable being too tight slightly opening the tb... tps adjusted accurate?? is it just idling high? no surging?
Try not using the gasket and just use honda bond.. A very light coat of honda bond did the trick on the one that one of my customers had. Hope this helps.
Re: (pb16b)
there's no IACV on OBD2 vehicles are there? does it rev up like normal? check the spark plugs and plugs going to the dizzy. they could be in the wrong order. that happened to me and i idled around the same rpm.
he never said his idle surges did he?
Re: (Advan06)
true that... he never stated that his idle surges... changing a throttle body and then having the idle at 2500 rpm sounds just like a vaccum leak and when there are, they surge. but sure... and yes obd2 vehicles do have iacv. try unplugging the iacv when it's up at 2500 rpm. if your engine dies or idle drops, your iacv's good.
Re: (pb16b)
there is no idle surging, when the car starts up, it idles normal, after it warms up, clutch is disengaged and in neutral, the idles goes up to 2800-3000, it doesn't surge,
Re: (jwamp316)
shouldn't be a vaccum leak then... nor tps... nor iacv... how about the throttle body pulley stop screw? is that screw turned in keeping your tb partially open? throttle cable too tight? can't think of anything else. er????
Re: (jwamp316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwamp316 »</TD></TR><TR><TD CLASS="quote">screw is ok, it sits right where the throttle body closes, i think i just got a bad tb</TD></TR></TABLE>
yeah that sucks...
yeah that sucks...
someone from str is here on the boards..but i forgot the screen name..but they are here somewhere...who knows they might find the thread and PM you..i know they did it for me
rasta420
04-22-2003 01:02 PM
