need help: 92 prelude seats into my 92 cx, having issues
does anybody have an actual up-to-date write up of this installation, most of the ones i have found either aren't informative or do not have pictures to show how to bend the seat rail, etc.
if anyone could help me out here it would be much appreciated
Re: need help: 92 prelude seats into my 92 cx, having issues (see_our_vtec)
do you still have your stock cx seats? If so, just look at the s2000 seat swap thread. Which is located in the How tos on the first page of the EG board and look under the header in the first post for interior. If you swap the seat pans and everything that goes along with it, it will fit in perfect. I had GSR cloths in my 93 cx, and i accomplished this this weekend, and they fit perfect. All of the holes line up and everything, and they are ever sooo comfortable. Hope this helped you a little. If you have any questions tho, feel free to e-mail me at rob_ace@hotmail.com and i will help you out more in depth.
Re: need help: 92 prelude seats into my 92 cx, having issues (HatchiHatch)
i was curious to see if the seat rails from the civic would swap over onto the lude seats, alot of the dimensions are the same but they don't appear as if they would fit right on the seat, and one or more of the bolts wouldn't be able to bolt up.
i've read that you can bend the lude rails to fit, but i've never seen how and that is what i am really looking for.
Location: In the middle of a gang warzone SOCAL, CA, USA
Re: need help: 92 prelude seats into my 92 cx, having issues (SpydiR)
bump cuz i searched for this in the archives..
any luck with a write up or pics???
Re: need help: 92 prelude seats into my 92 cx, having issues (bizzzzzz)
what I did was use the stock Prelude pans & sliders & bolted them in. Only 3 of the holes would line up though. What I will be doing as soon as I have access to a welder, is cut off the stock civic slider portion for the 4th hole & weld that to teh Prelude rail. Doing this will extend the Prelude rail enough, and place the 4th bolt hole correctly so that all 4 bolts are holding the seat down.
Re: need help: 92 prelude seats into my 92 cx, having issues (DJ_SaNdOz)
would you happen to have any pix of the progress? finished?
