HELP..96 Spec Type R Wheels on eg
I need some help here.
Im about to get some 96 spec type r wheels for my eg. When I do, my problem will be installing them on my car. I know the bolt patterns are different, so how can I make them fit?
I herd to take them 2 a machine shop and make them the 4x100, but i dont wanna do that to the wheels if i dont absolutly have to.
What else can I do??
Thanks for the help.
Re: HELP..96 Spec Type R Wheels on eg (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Swap to a 4x114.3 brake setup like I and many others have done. That's how you make them fit. </TD></TR></TABLE>
Is the typr r conversion the only one w/ that pattern? Or will a gsr set up work/have the same pattern? also What would I be looking to spend? Thanks.
Re: HELP..96 Spec Type R Wheels on eg (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso »</TD></TR><TR><TD CLASS="quote">From what I know isn't the type r a five bolt pattern?</TD></TR></TABLE>
I am talking about the 96 spec type r where its only a 4 lug.
Re: HELP..96 Spec Type R Wheels on eg (1992vxhatch)
QUOTE=1992vxhatch]
Is the typr r conversion the only one w/ that pattern? Or will a gsr set up work/have the same pattern? also What would I be looking to spend? Thanks.[/QUOTE]
ANYONE KNOW?????
ANYONE KNOW?????
GSR wont work, you might be able to use prelude but im not 100% on that. Best best it pay the 1100 for the setup.
have fun
https://honda-tech.com/zerothread?id=514109
please learn to SEARCH this could have been found by searching "ITR lug" limiting search to "eg+ civic/del sol" forum....click on archive topics
you need a 3 character string for search hence I did not use "4"
yep...u need to do the type r brake conversion to fit em
Re: HELP..96 Spec Type R Wheels on eg (itr_eg)
on my swap i spent 500 dollars for everything including rims and lower control arms and steel braided brake lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Swap to a 4x114.3 brake setup. That's how you make them fit. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">
you need a 3 character string for search hence I did not use "4"</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=979961
