sensors? i searched
sensors? i searched
are the engine sensors such as the iacv, o2 etc..the same from a 95 eg and a 95 teg? im looking at buying a b18b that does not have either manifold along w/ the sensors? can ne one help me out w/ an answer, thanx..
Re: sensors? i searched (wifesaynogo)
you can use the 02 sensor.
the IACV.....depends on the EG and the TEG
There are two types of Honda IACVs, 2 wire and 3 wire. The 3 wires are attached to the TBs the 2 wires are typically on the manifold.
Re: sensors? i searched (Spade)
ok what about all the other sensors? thise longblock is coming with zero sensors, and i know the sensors from honda are expensive...so are the rest of the sensors compatible? if it matters the its a 95 dx and the b18 is from a 95 ls
When I did the B18 swap in my friend's 92 EG, most of the sensors swapped over without trouble. The B18 was from a '94, since you're going from 95-95, it's even more likely that they'll all work. The only difference between the two in my experience was the mounting location of the MAP sensor if I remeber correctly, but that didn't cause any problems.
If for some reason they don't all work, you don't HAVE to go to the dealer and pay high prices. Just remember, you can always go to the pick and pull and get some from a 94-95 teg to save some $$$.
cloudconnected85
10-02-2012 10:14 AM
