Having problem With my Eg Headlight please HELP
for some reason the passenger side headlite of my car is having problem's
the high bean work's fine..just the low bean isn't working.
coudn't find the problem.i switch the passenger side headlight over to driver side work's fine............
does any1 out there got the DIY for the headligth Harness ??
or maybe got a pic of the EG fuse Box..i need the fuse details
Re: Having problem With my Eg Headlight please HELP (DJNauTicz)
If i remember correctly... the fuse for the lowbeam under the dash is, from looking at the fuse box straight on, the top row, 3rd from the right.
ill check that in the morning though. probablly a fuse problem, did it just go one day??
Re: Having problem With my Eg Headlight please HELP (dohcdelsol)
yea that i do know..but i lost the info on that..that's why i need the fuse box info for it..
by anychance do u guys got the fuse box info? or pix
Re: (civicseth)
one more question..all the Eg's Coupe Fuse Box Coupe Diagram are the same..or they are all diffent's ????
i got a 93 SI..so would that be the same ???
Re: (Morning Call)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call »</TD></TR><TR><TD CLASS="quote">their different
just check all your fuses</TD></TR></TABLE>
I think they're only different because of the extra additions/options the EX offers. I have an EX fuse block panel in my hatch.
Re: Re: (SlowPokeEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowPokeEg »</TD></TR><TR><TD CLASS="quote">Try the bulb.........
I had the same problem, changed the buld, voila! </TD></TR></TABLE>
In his post he said he switched it to the driver's side and it worked fine. So it could either be a wiring or or a fuse issue. I have a 1995 Si. I will check my fusebox panel and see if it matches the one posted above.
Modified by White95SiHB at 2:09 AM 5/13/2005
To my knowledge the fuse locations are the same for all models, some just have more for extra options.
If the fuse doesn't fix it, check the wiring near the connector for the bulb, I fried one on my EK.
Re: Re: (96-EJ6 B18C)
yea..i just need a pic that i can see all the fuse located..but i got an SI..so i'm scare it might be diffent..cuz i'm tryin to switch some of the stuff that's why.i need a better picture of the fuse box's..so pelase help thanks..
Dropspeed
04-21-2011 05:34 AM
