help??tire question size?
Re: help??tire question size? (mattjars)
what size rims?
as far as clearance yes. But you have to make sure you have 17inch rims first and if so then they more then likely will fit
Re: help??tire question size? (mordezmoncou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattjars »</TD></TR><TR><TD CLASS="quote">will 215/50/17's fit on a 99 civic ex coupe?</TD></TR></TABLE>
your gona have to give us more info. how much is your car lowered?
ok lets see 215/50/"17" so im guessin 17 in.rims dumb ***...or maybe ill squeeze 18 in. into the 17 tires...
but for the more intellegent people, the car is lowered 2" with neuspeed springs
Darth ModerVader
The tires you're asking about are nowhere near the correct size for your Civic. The car's stock overall tire diameter is 23.44". The tires you mentioned will result in an overall diameter of 25.46, which will greatly affect your gearing and your speedometer accuracy. The 17" tire with an overall diameter closest to your stock setup would be 205/40-17, and that's what I would suggest using if you insist on running a 17" wheel.
Re: (mattjars)
[QUOTE=mattjars]ok lets see 215/50/"17" so im guessin 17 in.rims dumb ***...or maybe ill squeeze 18 in. into the 17 tires...
HAHAHAHAHA! You took the words right outta my mouth
Phailzilla
07-19-2013 06:08 PM
spaceman00
03-18-2007 11:30 AM
spaceman00
30
02-17-2007 12:49 AM
jazzdacbiet
11-05-2005 01:42 AM
