How to remove airbag?
How do I remove the airbag in my 93 cx? I am doing a black interior conversion. I cant seem to get the screw that connects the airbag to the steering wheel.
A freind recommended to drill the screw out and replace it with another screw. Please help my car is completely unbolted.
Modified by dchan86 at 10:21 AM 5/8/2005
Re: How to remove airbag? (dchan86)
its actually a crazy looking screw ! u need a certain tool to undo the air bag screws ! the tool i got its called a t-38 screw ! it unbolt my air bag no problem ! i know its not much help sorry
Make sure you disconnect the battery ground first. Then use the torx bit to remove the screws. Make sure you do not move the SRS reel at all when re-installing your new airbag, or the SRS light may stay on.
Re: (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">T30 torx bit.
http://www.hondaswap.com/forum...35291</TD></TR></TABLE>
lol omg i can't believe you were going to drill it out. I would have laughed so damn hard if you did like a DIY on how to remove the airbag and it went like, "Step 1. Drill out the crazy screw!"
ok anyways im a loser.
That screw right there is only one, there should be another one on the right side of the airbag.
Re: (The-Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast »</TD></TR><TR><TD CLASS="quote">lol omg i can't believe you were going to drill it out. I would have laughed so damn hard if you did like a DIY on how to remove the airbag and it went like, "Step 1. Drill out the crazy screw!"
That screw right there is only one, there should be another one on the right side of the airbag.</TD></TR></TABLE>
Drill? Who said drill, Torx is a star patterned screw.
Re: How to remove airbag? (mikaleg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikaleg6 »</TD></TR><TR><TD CLASS="quote">Make sure you disconnect the battery ground first. Then use the torx bit to remove the screws. Make sure you do not move the SRS reel at all when re-installing your new airbag, or the SRS light may stay on.</TD></TR></TABLE>
Can someone point out the battery ground and the SRS reel.
Re: (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Drill? Who said drill, Torx is a star patterned screw.</TD></TR></TABLE>
The first post....
The first post....
Re: (Revolver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver »</TD></TR><TR><TD CLASS="quote">The first post....</TD></TR></TABLE>
Yea, I see that, but he quoted me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchan86 »</TD></TR><TR><TD CLASS="quote">
Can someone point out the battery ground and the SRS reel.</TD></TR></TABLE>
Anyone?
Anyone?
the srs reel is the yellow and black sorta circle type part in the steering wheel, the battery ground is pretty self explanitory, pop the hood, disconnect the ground on the battery
Re: How to remove airbag? (FarOutCoupe)
You should also use the jumper to disable the airbag, otherwise you might knock your head off if the airbag deploys while u are unscrewing it.
I would never recommend drilling that close to the SRS, a torx bit works fine.
Re: How to remove airbag? (The-Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast »</TD></TR><TR><TD CLASS="quote">oh lol whoops. I meant to quote you on the using the torx bit and then make a comment on the first post =P</TD></TR></TABLE>
the big ragu
06-09-2002 12:01 PM
