2000 Si Engine problem
The car is a 2000 Civic Si, with a Vortech S/C. It has been running fine, always gets regular service(oil change, plugs/wires, etc). Out of nowhere the other day, it started running weird. From a dead stop, and when at low RPM, the engine bogs, and makes almost a "put-put-put-put" sound. But when I get on it, and run it up into VTEC, the power seems to pretty much be there. I've had some people tell me that the catalytic converter might be plugged up. I went to take it off and check, but the bolts are stripped, so I'm going to have to have someone cut the bolts. Any help or suggestions would be great, I'm freaking out about this.
Re: 2000 Si Engine problem (premo_si)
Anyone, the check engine light came on when I started it up today, and I'll have my scanner tommorrow, so maybe that will help. Any ideas as to what it might be?
The CEL codes were
P0131 - O2 sensor circuit low volts(bank 1 sensor 1)
and
P1399 - Manufacturers Control Ignition System or Misfire
Please anyone, I need this thing fixed!!!
and
Re: (premo_si)
i had a problem that was similar the first 02 sensor in the header controls the amount of fuel going to your vehicle(block temp. i think). For example if the 02 sensor is reading low(cold) it will dump mad fuel and you will be running super rich and get like 180mi to a full tank of gas. This could possible be the problem with low idle issues and being boosted and having this is probably not good giving the Misfire CEL change the 02 sensor in the header and hopefully things should clear up. could be wrong but that was my issue but i wasn't boosted either.
GOOD LUCK
GOOD LUCK
Global Moderator
Re: (Spoolinator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolinator »</TD></TR><TR><TD CLASS="quote">Yea, just pee in the gas tank, It will clear it right up!</TD></TR></TABLE>
WOW! Great reply
Pull your plugs, if it has cylinder misfire.. also check out your plug wires.
WOW! Great reply
Re: (Spoolinator)
wow maybe he should have the nOOb sign
yea check ur plugs man, maybe done for. good luck
ricmac007
20
05-15-2009 10:11 PM
00EKcivic55
10
08-26-2006 09:44 PM
