Thermostat problem?
Thermostat problem?
CEL 10- IAT - intake air temperature sensor
After driving for about 10 mins the car start stalling, heater is always cold, and i cant tell if its over heating because the temp gauge isnt working but smoke is coming up from around the water pipe and i can hear sizzling noises..
The symptoms are:
-Radiator fan dont turn on
-Coolant reservoir always full, coolant doesnt get suck in
-Top hose is hot, bottom is cold
-Heater always cold
-Car starts to stall after 10 mins of driving
-Smoke coming up from under the IM..water pipe?
The symptoms are:
-Heater always cold
i got same problem with fan not coming on. ima goto a junk yeard and jack a relay, see what happens. you can also run a loop on the thermostat housing sensor and it will run continuosly
simplegreenmachine
13
12-12-2009 04:07 PM
ZC88CRX
09-02-2003 09:57 AM
