cant hear my vtec
cant hear my vtec
i just recently built my y8 and when i put the motor back in and broke it in i realized that i couldnt hear my vetec anymore. i checked all the connections and i was really carefull when it was of the head, so i really dont know what happened to it anyone have any suggestions?
Re: (KingElli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingElli »</TD></TR><TR><TD CLASS="quote">Can you even hear vtec engage in a sohc vtec motor???</TD></TR></TABLE>
yeah
yeah
I havent checked my valve lash since I did my mini me... but I cant hear it either... Only way I know that vtec is engaged is because my oil pressure drops a bit when it engages since vtec is a hydraulic system I watch my oil pressure gauge to see when it engages. I have an intake, edelbrock intake mani, headers and exhaust... My Y8 head is also ported and polished..
Re: (Boosted96EK)
my check engine light is on but i think that is from my test pipe it was on b4 this problem i also have a problem with my speedometer it keeps going to zero and staying
Re: (Boosted96EK)
If you have all that you should be able to hear VTEC....i mean with my d16z6 I just had a short ram intake and I could hear the crossover distinctly.
Get an LED, hook the positive up to the VTEC solenoid and the negative to ground......see if it lights up when VTEC is supposed to be engaged.
Re: (egsleepercivic)
just like eg sleeper said your vss is screwed as it was in mine so it aint goin to ingage. and even when you get that fixed if your check engine light is still on you got another problem so you still wont be hittin tec
Re: (4dr*sleeper)
ok so what is the Vss sorry i havnt learned all the abrieviations yet i was able to hear it before i but now i cant could it just be the vetec solinoid?
Re: (KingElli)
Its not nearly as noticeable as it is on a dual cam.
