Question about Si lip?
I am planning on getting an Si lip for my 99 Ex and I was wondering what I need besides the lip?
Am I going to need number's
35,36,37,39,40,41,42,43, and 44? If so how much do I need of each?
Re: Question about Si lip? (donut.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. »</TD></TR><TR><TD CLASS="quote">you basically just need 39 and 41.. go look at the bottom of your bumper to see how many you need of each</TD></TR></TABLE>
i get # 42 too. make the lip fit tighter on the sides..
Re: Question about Si lip? (dawrenn)
#41 is the mounting bracket thingy that clip onto the front bumper and #39,40,43,44 is the bolts that screw to the #41,42 to hold the lip to the bumper
NOTE: there is more bolts and mounting clips needed then the picture shown
Re: Question about Si lip? (HATCHingMN)
When you get the lip go down to the hardware store and crab a few matched nuts and bolts and screws for the sides and maybe some washers to make the lip fit better on the sides. Don't need oem nuts/bolts/screws for this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">#41 is the mounting bracket thingy that clip onto the front bumper and #39,40,43,44 is the bolts that screw to the #41,42 to hold the lip to the bumper
NOTE: there is more bolts and mounting clips needed then the picture shown</TD></TR></TABLE>
I think it just shows that for a general idea. When you click on them you can add more to the cart.
39 and 44 are the same thin, How much would I need of them?. I cant tell if #43 is a bolt or screw. Either way, how much would I need?
Re: Question about Si lip? (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">When you get the lip go down to the hardware store and crab a few matched nuts and bolts and screws for the sides and maybe some washers to make the lip fit better on the sides. Don't need oem nuts/bolts/screws for this.</TD></TR></TABLE>
Does #39 go with #41?
39 is the bolt, 41 is the clip they are sold seperatly. When I went to get mine I got the clips at a salvage yard and I got the bolts from Honda I think you will need 11 of them ends up being about 20 bucks for the bolts alonw so if you have a salvage yard so pirate them off another car before going to Honda. Someone else mentioned not using OEM parts and on this I would go OEM all the way. It may cost a little but riggin up that many bolts nuts and washerd seems to be a pain in the *** and not worth the 10-20 bucks you would save. for the screws on the side I think #42 and #40 just get some 3/4" self tapping screws that is the only place I would suggest going non OEM. Mine is on and I have had no probs at all.
Re: Question about Si lip? (ralphie14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 »</TD></TR><TR><TD CLASS="quote">39 is the bolt, 41 is the clip they are sold seperatly. When I went to get mine I got the clips at a salvage yard and I got the bolts from Honda I think you will need 11 of them ends up being about 20 bucks for the bolts alonw so if you have a salvage yard so pirate them off another car before going to Honda. Someone else mentioned not using OEM parts and on this I would go OEM all the way. It may cost a little but riggin up that many bolts nuts and washerd seems to be a pain in the *** and not worth the 10-20 bucks you would save. for the screws on the side I think #42 and #40 just get some 3/4" self tapping screws that is the only place I would suggest going non OEM. Mine is on and I have had no probs at all.</TD></TR></TABLE>
I actually already had random nuts and bolts in my tool shed so it was free, but it costs like a few cents per nut, bolt, washer, and screw at the hardware store. I don't see how much of a pain in the *** it is to pick up some nuts and bolts from the store and put them on compared to going to the dealership and asking for each and every bolt and finding out they don't have all of them in stock and having to wait for them to order and paying much more money. The best part of using the kind of bolts I used is that for a theif to try and steal the lip from my car they'd have to either rip it off causing severe damage to the lip and probably tearing it to pieces or they'd have to take off my whole bumper and grille. You can't undo these bolts from the outside, you have to take the bumper off to undo them. Now I don't know how the oem hardware attaches the lip to the bumper, but it's probably easy to remove from the outside.
Re: Question about Si lip? (1type)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1type »</TD></TR><TR><TD CLASS="quote">i get # 42 too. make the lip fit tighter on the sides..</TD></TR></TABLE>
Well if you get that, then I'm pretty sure you'll also need #40.
have fun having Honda charge your 3 dollars a screw when you can just find them at home depot for a few cents. cmon guys its just some screws and brackets!
Re: (jerbear!)
yea i bought screws at the dealer. thankfully they only had about 2 bolts and nuts so i went to the hardware store instead and pieced a few sets myself. i got about 5 or 6 bolts, washers, and nuts and that was about the same price as 2 bolts at the dealer
You are correct, there are 11.
71112-S04-Z00 035 BRACKET, R. FR. SPOILER - 1 $4.41
71113-S04-Z00 036 BRACKET, L. FR. SPOILER - 1 $4.41
75522-611-000 037 GROMMET, SCREW (4MM) - 4 $2.55
93405-08025-08 038 BOLT-WASHER (8X25) - 2 $0.87
90111-SM4-003 039 BOLT, BUMPER - 7 $1.52
90114-SE0-000 040 SCREW-WASHER, TAPPING (5X20) - 4 $1.69
90305-SH3-000 041 NUT, AIR SPOILER CLIP - 9$2.34
90345-S04-000 042 NUT, SUSPENSION (5MM) - 4 $1.70
93903-14480 043 SCREW, TAPPING (4X16) - 4 $0.29
90111-SM4-003 044 BOLT, BUMPER - 2 $1.52
For those who bought from Home Depot, what size nuts & bolts did you buy? The guy I bought my lip from said it came with hardware, but when I picked it up, none were included. It's been over two months & still nothing from the seller so I guess I'll go the hardware route.
Re: (EG-CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-CX »</TD></TR><TR><TD CLASS="quote">For those who bought from Home Depot, what size nuts & bolts did you buy? The guy I bought my lip from said it came with hardware, but when I picked it up, none were included. It's been over two months & still nothing from the seller so I guess I'll go the hardware route.</TD></TR></TABLE>
find a nut/screw, get a washer, drill that **** into ur bumper and VIOLA ITS MOUNTED!
ps. 3m adhesive tape will also help
Mr. Indecisive
Re: (EG-CX)
u waited 2 months for some nuts n bolts??? hahaha
CoupeVtec2k - The guy I bought it from just opened a shop locally. He misplaced the hardware when he moved his stuff to the new shop plus I was gathering my suspension pieces (Tanabe coilovers, Progress 24mm adjustable rear swaybar, DC2 rear LCA's) & finally fat fives. He says he will get them to me, but I figure I'd ask in this thread.
Yeah, 2mths... I'd rather do it all in one shot!
