vtec spool valves
vtec spool valves
hello everyone,
im looking for a vtec spool valve, solenoid or whatever its called for a 94 civic coupe with D16Z6 engine. Anyone got any links or directions for where to get it?
Is there any way to repair it?
regards
francesco.
regards
francesco.
H-T White Ops
The solenoid is actually bad? Have you tested it with a 12V power supply? If it doesn't open up the windings inside the coil are open and need to be replaced.
I've always had good luck with getting parts from http://www.majestichonda.com
Unceasing Measure
Re: vtec spool valves (HATCHingMN)
Spool valve errors (CELs) usually arise when the screen in the VTEC solenoid has deteriorated to the point of letting **** into the spool valve, thus clogging oil passage into the VTEC sensor.
Clean it out and get a new screen for like $10 at Honda.
i´ve tried cleaning it with carb cleaner. The filter seems fine visually. Going to try 12v directly and see what happends.
regards.
francesco.
regards.
francesco.
lol its expensive, i have an extra laying around. they will run you for about $200. but pm me if you still need it i can sell you mine for half that price. It;s off a EJ8, but i think it should work for ur Z6 as well...pm me..
Flatland2D
07-16-2010 09:14 AM
