Does Using a/c affect engine temps?!??!
Old Jul 2, 2005 | 07:49 PM
needaimport's Avatar
Default Does Using a/c affect engine temps?!??!
my car will overheat when i turn on the a/c, why is that?
driving in houston heat w/o a/c is horrible.
the car only overheats if my a/c is turned on for a while. itll spike all the way up and then go down a little (but still hotter than usual) and go up again etc etc etc.
ive been told that the a/c shouoldnt affect anyhting.
TIA
Old Jul 2, 2005 | 07:53 PM
The_Todd's Avatar
Farts in the shower
Default Re: Does Using a/c affect engine temps?!??! (needaimport)
The a/c compressor when it turns on puts a load on the engine and creates heat. Also when you run the condensor that usually displaces some heat too...all that added to your engine will create more heat to the entire system but your car should not overheat since your water pump/thermostat and radiator control that.
I would look into the following in this order:
your radiator fluid levels
any cracks or leaks in your cooling system
that your radiator fan is turning on
relays to fan are operable
your thermostat is opening up
BTW is your radiator a single or dual core?
Old Jul 2, 2005 | 09:36 PM
Default Re: Does Using a/c affect engine temps?!??! (.ken)
dunno, its a 94 civic and i got a $99 replacement radiator sometime.
ill get to checking those, thanks.
Old Jul 2, 2005 | 10:10 PM
Crazydave's Avatar
Depending on the A/C setup, it may turn the radiator fan on as well, which will help keep the engine coolant in check.
Old Jul 3, 2005 | 05:40 AM
Frozen E's Avatar
H-T White Ops
Check your T-Stat
^LORTA^RACING
Apr 21, 2005 08:53 PM
buttsneeze
Apr 13, 2005 10:52 AM
fe519
Jul 27, 2004 09:41 AM
mickey513
Mar 18, 2004 06:18 AM
Fatty_1775
Jun 28, 2003 10:32 PM
