92 Civic hatch - TYPE R D brackets - NEED ANSWERING!
can I straight bolt on a stock integra type R rear sway bar and D brackets onto my 1992 Civc hatch frame?
if not is the beaks kit suppose to solve this problem or is the beaks kit just suppose to prevent frame tearing?
Any info would be appreciated...
Re: 92 Civic hatch - TYPE R D brackets - NEED ANSWERING! (piatl7il77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piatl7il77 »</TD></TR><TR><TD CLASS="quote">can I straight bolt on a stock integra type R rear sway bar and D brackets onto my 1992 Civc hatch frame?
Any info would be appreciated... </TD></TR></TABLE>
if you have holes on your rear lca's (94+integra lca's) then yes you can bolt up the sway bar, and the beaks kits is just to add more support to the lower frame. i use the cheaper bsq kit and it works just the same and is cheaper. look in the suspension section for a debate between the two..
but how come when I tried bolting up the type R D brackets up to my civic....only the top bolt fits because the length of the D bracket holes are farther apart then on the Civic.
or am I just bolting them on wrong?
sc_92_civic_hatch
01-26-2004 11:47 AM
plusONE jboy
11-27-2003 11:16 AM
donkeypunch
03-28-2002 03:43 AM
