bigger injecters? what else do i need to change?
i am bout to swap my motor in but i still need to add a few things. if i get bigger injecters what else do i need to change so it can run clean??? help me out here i need to swap my **** in.
Re: bigger injecters? what else do i need to change? (k20a2ek-9)
fuel pump
And a few more details would be nice. What is the current motor? What motor is going in?
depending on how big of injectors you go will help determine what all you need. Lets say you do 1 million cc injectors, you will need something to to control the amount of added fuel,I.e. a vafc, a chipped ecu, some sort of Stand alone,etc,etc... Also a fuel pump. like a walboro 190 lph or 255 lph. or once again you can go crazy and do like a 1000 lph external pump. Or even dual pumps.
Re: bigger injecters? what else do i need to change? (sohcvtec1995)
right on, so it all depends on what size injeceters i get. anyone have a good brand and size that would help me out so my car can run clean? do you think i can jus get injecters and fuel rail and regulater for now so i can get my motor in and then later on do the rest. i aint goin to race my car right away.
the motor that you are putting in is pretty much stock. just use the factory stuff. A fuel rail is pointless unless you are makeing lots and lots of power, or you need a nitrious tap. A regulator will help, but it can only do as much as your fuel pump will allow. as far as injectors, i would base that off of what you plan on doing with the car in the future.
sircrxracer
11-21-2003 10:24 AM
