Bent rim + inspection?
i've got Rota C8's on my 99SI............the LIP is bent on the driver's front, is that failure?
-also one tire is at/right at hte wear bars on just the outside due to be'n underinflated and the center is fine, failure?
thanks!
thanks!
Re: Bent rim + inspection? (Senses Fail y0!)
read the post before replying like a retard...........the LIP is whats damged, NOT the rim........the rim itself is perfectly round, just the very outside part of the lip has a flat spot
be professional
Re: Bent rim + inspection? (tthomass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass »</TD></TR><TR><TD CLASS="quote">-also one tire is at/right at hte wear bars on just the outside due to be'n underinflated and the center is fine, failure?</TD></TR></TABLE>
If 2/32nds of tread is the limit, then yes, they can fail you. Doesn't matter if there is more tread on the rest of the tire.
Re: Bent rim + inspection? (JDM PRO)
They shouldn't fail you for the tire wear, my car passed and mine had crazy wear, but the center was 2/32 in 2 spots. They measure in 2 spots for the 2/32. Im also pretty positive if your rim, if it is balanced correctly, should pass. Was It from a curb??
Re: Bent rim + inspection? (BG Enjoi)
from a pothole.....you'd have to own a C8 or be really familar with them to know what part i'm talk'n about.............the tire is seated just fine, its like the little piece that flares out. I'd get a pic but can't at the moment...............i figured inspectors call, we'll see how it goes...........should be fine, again its not bad.............thanks!
Re: Bent rim + inspection? (eXcelonTypeR)
i'll find out ahead of time if he'll fail me, if so i'll just wait till i'm home for the weekend where i know i can pass................n. va has some picky bastards over little stuff besides the rim.............thanks for the help
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">think about it this way, if he fails you, he's just being better safe than sorry</TD></TR></TABLE>
And covering his own ***. Liability is a bitch.
Re: Bent rim + inspection? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Liability is a bitch.</TD></TR></TABLE>
agreed
agreed
A.K.A JDM DRUNKEN MONKEY
02-02-2003 03:07 PM
