weird electrical problem
I get to the parts store last night to pickup some brakes for my other car, I was driving my 97 civic h/b, and notice the speedo stoped working...then ALL (headlight, all interior, tails) the lights are dimming, back on, dimming, then back on...just doing that constantly...also the speedo is acting real weird too, it's not reading the speed, it's just jumping all over the place...going down to 220, then back down...it seems to be just jumping around randomly...this is happening under load, at idle, everywhere..my audio is completally off
I got no idea where to even start looking...seems like a bad ground...but not sure how to troubleshoot this
this started happening as I pulled into the parts store...was fine all the way there, and did it all the way back
the car still drives but it does this...messed up
Re: weird electrical problem (Leb_CRX)
there is a brown wire on the back of the intake manifold that may be rubbed raw. Look for it where the loom is making contact. You also have the year that came with the batch of defective alternators on a portion of them. A failing voltage regulator inside can cause some of these symptoms...not the bouncing speedo though.
A bad ground at the battery can always cause havoc across an entire electrical system.Happy hunting
Re: weird electrical problem (Chiovnidca)
my CEL light is burnt out
tell ya teh truth I never even thought that this could be throwing a code, I will put in a new bulb when I get home and check it out
oh ya and Moto...I have a Y8 IM swap...and I didnt extend none of the wires there...and they are real tight, I will check that out too
Re: weird electrical problem (Luserkid)
they been fine
but here's the thing, if it was alt/batt, why would they be dimming and back on randomly, both under load and idling?
I would think it would have diff symptons, correct me if I'm wrong
checked the CEL's after resetting it again
code 41 and 65
45 Fuel system too rich or lean
65 Secondary oxygen sensor heater
45 wouldn't cause it
65 could, so I disconnected my 2nd o2, which should bypass all electrical from going there and the problem remains
I made sure to reset the ECU in between
code 41 and 65
another thing, doesn't seem to do it right away, sometimes
when I first reset the ECU, it didn't do it until I started moving
then after I was pulling into my lane, when I put it in R...ti stoped for a few seconds, then staretd back up
seems real intermittent
I gotta find me a spare distributor to test this
Re: (Leb_CRX)
On both of the things I mentioned they are factory technical service bullitens and issues in stock form. As to the loom, it was doing it from factory set ups so yours may be more prone. As to the voltage regulator, I went through this with my personal vehicle and have seen it on many customers cars. The voltage regulator in the alt starts going and it clips the amount that the alt can charge so the voltage swings back and forth rapidly up to 4 volts depending on the condition of your battery, stereo mods, etc. It may get worse, it may go away for a few months and return.
if you have a volt meter check it out and it will be easy to catch. usually suspect cars will only be charging at 12. something at idle. If so, dead ringer. It could be other things like ground issues but on that particular car these are two things to definately rule out before chasing your tail on a ground fault that could be many places.
Re: (moto1320)
ground is fine,
also checked for wires behind IM...all appear fine
I tested the alt+batt both seem fine
charges at about 13.7ish with some throttle
idle like 12ish I believe
here's another thing I realized
if I start the car and just let it idle...it's ok
as soon as I touch the gas, is when the jumping of lights begin
I am gonna take the alternator from another car to test it, any other ideas meanwhile?
it almost feels like the car is chugging, but it's doing this jumping even under load
this is so confusing, I hate cars
Re: (Leb_CRX)
My 98 Civic EX did the same thing where when you hit the gas the lights inside and out would dim. Even when I hit the brakes... I didn't pay much attention to it though because I was trading it in for my Prelude. And a light was out above my temperature sensor... it was weird...
Good luck though...
Good luck though...
Re: (Leb_CRX)
my 97 ex was just doing the same thing.....check the #15 fuse under the dash on the driver's side.....i replaced it and all my problems were gone.....no more lights dimming speedo works again and everything is cool.....good luck man
thannon2
01-15-2009 07:10 PM
AllMotorBrew
12-05-2003 11:25 AM
