disk brake conversion
I own a 95' civic 4dr I was 10 minutes from selling it in favor of a crx I'm going b18 ramhorn turbo then I thought about it, no one I want to prove that I can compete in a four door so as I was looking for parts for the rex I came across some brembo rotors(set of four slotted and cross drilled at oem size, for crx), I needed new front rotors any way so I was wondering if the front ones will fit and what will I need to make the rear ones fit . . . . .will I need the rear hubs off of an si, hatch? Or a rex?
Re: disk brake conversion (el_payaso)
For which car? the rex? the sedan? please edit what you are asking. I highly doubt telling us that you want to go turbo has anything to do with your actual question.
Re: disk brake conversion (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">For which car? the rex? the sedan? please edit what you are asking. I highly doubt telling us that you want to go turbo has anything to do with your actual question.</TD></TR></TABLE>
i think he means will the crx rotors fit on the 4dr...and ur right about turbo having nothin to do with the actual question
Re: disk brake conversion (dc2vu)
Well in that case. You need the rear trailing arms from a 92-00 civic/94+ integra. Also e brake cables, Optional 40/40 PPV, Brake Booster.
precord96
09-09-2003 08:05 AM
