what way to turn dixxy for advanced timing
what way to turn dizzy for advanced timing
all the colors are shot but i can still make use of the 3 groovs. since i cant see the colors i need to know what way to turn the dizzy to advance my timing
Re: what way to turn dizzy for advanced timing (hamburgler)
you rotate it towards the rear for advance (towards Intake Manifold) towards the front for retard. Hope that helps.
Re: what way to turn dizzy for advanced timing (HuntsvegasHatch)
ok thanks, i cant see an arrow like some instructions say but i did find a small groove that looks like it could be the arrow because the color bars on the crank pully were really close.
shoot from the hip and pray? no really just tune moderatly and drive it to see if you get the results you want. If not keep tuning.
BTW depending on your car you made need to jumper the diagnostic plug while tuning otherwise the ECU will correct anything you change and then you are just wasting your time
yeah did this all, car pulls better at 16 degrees than advanced to 18 degrees. any reason for this? i followed c-speedracing.com instructions
oh also when i jumped the diagnostic wires i got a code 20 on the dash
88-98 Civic
97-98 CRV
92-98 Prelude
94+ Integra Electrical Load Detector defective circuit or unplugged / defective sensor
unplugged it and the code went away. weird
88-98 Civic
97-98 CRV
92-98 Prelude
sometimes codes don't show but are stored in the ecu (not cleared yet) and why are you doing the timing advance just for an intake?
i just advanved it to 18 degrees to see if it made any difference and i didnt. it made the car run worse. so its about 17 degrees right now but obviously its hard to tell. my intake really only consists of cotton over the throttle body. bad idea i wouldnt recommend it
brokenojoke
Engine Management and Tuning
06-14-2008 09:50 PM
