Gaskets
Cigarette Squad
Gaskets
can a intake manifold be a problem for not starting, such as if u bought a wrong one
and also is ground wires spose to get hot when cranking car.
Electrician
What are your symptoms? What happens when you try and crank the engine?
No, ground wires are not supposed to get hot when you crank your engine. Maybe, that's the problem on why it's not starting. You probably have some bad connections on the grounding wires and they aren't making proper contact to the connector and/or chassis.
Cigarette Squad
Re: (Deemeetree)
correction intake manifold gasket..
like engine starts but doesnt turn on.. and it backfired once when trying to crank
and the ground wires itself are getting hot..
Re: (So_Skilled_01)
What kind of car is this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by So_Skilled_01 »</TD></TR><TR><TD CLASS="quote">
like engine starts but doesnt turn on.. </TD></TR></TABLE>
and the ground wires itself are getting hot..</TD></TR></TABLE>
Which specific ground wires? All of them?
Cigarette Squad
Re: (green00EX)
its a 94 Honda Civic DX head LS block
like the one that connects fron the head to the front of the chassis
it wants to turn on but doesnt.. like u can hear it start then go out
i got a good spark and everything
Electrician
Re: (So_Skilled_01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by So_Skilled_01 »</TD></TR><TR><TD CLASS="quote">its a 94 Honda Civic DX head LS block
What the hell is this? D15B7 cylinder head and a B18B block?
Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">What the hell is this? D15B7 cylinder head and a B18B block? </TD></TR></TABLE>
LMFAO... i was wondering about this myself... maybe thats why your car wont start dude
Re: (So_Skilled_01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by So_Skilled_01 »</TD></TR><TR><TD CLASS="quote">its a 94 Honda Civic DX head LS block</TD></TR></TABLE>
that is your problem right there, you will never get that bitch started and if you, to you
Honda-Tech Platinum Member
Re: (neutron91)
lol man unless you were patient and skilled enough to make a supreme ls/dx machining to make them both fit then more power to you Need more clearer info
Cigarette Squad
Re: (BrokeAssPinoy)
lmao its a d series, my block blew from intake sucking whater into it.. so i bought new block
not b18 or w.e i went for the cheapest right now
Cigarette Squad
Re: (neutron91)
haha okay
forget everything ive said
i have a d15 b7 engine.. i have spark ive checked fuses and everything, i belive my timming is off a tooth or so
