AUTO 2 MANUAL
AUTO 2 MANUAL
I have a 93 civic dx, unfourtunately it is automatic. I was wandering if anyone would have any idea on what all i would need to make my car a manual. I already have the transmission and the shift linkage. Wat all kindof parts would i have to get in order for this 2 work. Thankyou in advance for your help in this project.
Imperious: Mod of Valor
Re: (1995Ex_Sedan)
Wow, this has been covered several times..
This is what you're going to need.
Manual Transmission
Clutch/Flywheel
Manual Starter
Shift Linkage
Pedal Assembly (Integra Pedal Assembly will work)
Hydraulic Lines
Clutch Resovir
Shiter
Shift ****
Slave/Mastyer Cylindar
Shift linkage Bushings
Manual ECU
Manual Console Piece
Shift Boot
Probably more, but that's the main parts.
Manual Transmission
Clutch/Flywheel
Manual Starter
Shift Linkage
Hydraulic Lines
Clutch Resovir
Shiter
Shift ****
Manual ECU
Shift Boot
Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Wow, this has been covered several times..
Manual Transmission
Clutch/Flywheel
Manual Starter
Shift Linkage
Hydraulic Lines
Clutch Resovir
Shiter
Shift ****
Manual ECU
Shift Boot
Probably more, but that's the main parts.</TD></TR></TABLE>
I'm not sure on '93, but '96-up you'd also need
Intake manifold
IACV sensor
Gauge cluster (optional)
Manual Transmission
Clutch/Flywheel
Manual Starter
Shift Linkage
Hydraulic Lines
Clutch Resovir
Shiter
Shift ****
Manual ECU
Shift Boot
Intake manifold
IACV sensor
