Integra tranny in a EG
Old 08-15-2005, 02:57 PM
cayman_hatch's Avatar
Default Integra tranny in a EG
I know B18 just really is a drop in swop but what about the tranny?
Will an Integra tranny bolt up in a EG6 or does it take modification?
Old 08-15-2005, 03:00 PM
JDM-97CX's Avatar
Default Re: Integra tranny in a EG (cayman_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cayman_hatch &raquo;</TD></TR><TR><TD CLASS="quote">I know B18 just really is a drop in swop but what about the tranny?
Will an Integra tranny bolt up in a EG6 or does it take modification?</TD></TR></TABLE>
A B-series trans will bolt up to a B-series engine. What car it is really really doesn't matter too much.
Old 08-15-2005, 03:15 PM
unknown0001's Avatar
Just make sure you have the 94+ integra mounts
Old 08-15-2005, 03:16 PM
SirRevvs's Avatar
Default Re: Integra tranny in a EG (JDM-97CX)
You can only use a B-Series transmission with a B-Series engine. And yes it bolts up fine. Check the top of the page for some helpful FAQ.
Old 08-15-2005, 03:17 PM
SirRevvs's Avatar
Default Re: Integra tranny in a EG (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure you have the 94+ integra mounts</TD></TR></TABLE>
It doesn't hurt but I'm pretty sure the tranny mount is the same with B and D series right?
Old 08-15-2005, 05:17 PM
B_series_'s Avatar
yep, should bolt right up, and yes you could use stock civic mounts, but you would be better off using the integra mounts.
Old 08-15-2005, 05:21 PM
A.E Motoring's Avatar
Default Re: Integra tranny in a EG (B_series_)
you can use your stock civic mounts...but your going to need the integra rear T bracket for the tranny
Old 08-15-2005, 05:23 PM
Default Re: Integra tranny in a EG (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">
It doesn't hurt but I'm pretty sure the tranny mount is the same with B and D series right?</TD></TR></TABLE>
From the b18a swap I've done last week, the D-series TOP tranny mount WONT work on a B-series motor
I'm going to say it will NOT WORK since the 3 bolts didn't even line up on the d-series mount to b-series mount(top tranny)
Click the link in my signature and read up on what I posted about the b18 swap into civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">you can use your stock civic mounts...but your going to need the integra rear T bracket for the tranny</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_series_ &raquo;</TD></TR><TR><TD CLASS="quote">yep, should bolt right up, and yes you could use stock civic mounts, but you would be better off using the integra mounts.</TD></TR></TABLE>
Have you guys even seen both the mounts and tried to line up the d-series mount on a b-series transmission???? It WONT line up all 3 holes properly. 1 hole will but the other 2 wont
Old 08-15-2005, 11:27 PM
says right here u can use your civic upper trans...this should help you out alot
JWhonda_ride
01-27-2008 06:31 AM
vtek9
08-16-2007 10:46 PM
crix351c
06-21-2005 09:29 PM
h22a92accordex
05-23-2005 08:40 AM
SleepyEG
03-25-2004 11:41 AM
Quick Reply: Integra tranny in a EG
