d16y8 vs. d16y7 intake
Old 08-16-2005, 08:44 AM
stealth_EK4's Avatar
Default d16y8 vs. d16y7 intake
I got a 98 hatch with the stock dx motor is it the d16y7 with the crazy TB pointed upward? my buddy has a intake mani. from a 99 d16y8 vtec, if I swap them will I feel a difference is the y8 much better??
Old 08-16-2005, 08:50 AM
b 1 6 a 2's Avatar
The d16y8 IM is the best flowing manifold there is for the sohc engines. You will probably notice a difference, but nothing major to tell all your friends about.
Old 08-16-2005, 08:51 AM
chinkest_raver's Avatar
Default Re: d16y8 vs. d16y7 intake (Coupe_SquadEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coupe_SquadEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I got a 98 hatch with the stock dx motor is it the d16y7 with the crazy TB pointed upward? my buddy has a intake mani. from a 99 d16y8 vtec, if I swap them will I feel a difference is the y8 much better??</TD></TR></TABLE>
well, you won't feel much of a difference. Since it is a non vtech. but give it a shot you might like the little, and i mean little extra power!! LOL by the way like ur sig!! lmao, wings are for planes...hhahahahahaha
but still like mines more!!
Old 08-16-2005, 08:55 AM
Default Re: d16y8 vs. d16y7 intake (*****est_raver)
im searching some sites and some people are saying you have to swap the ecu also because of the IAC valve is different
Old 08-16-2005, 11:57 AM
96CivicBoostCoupe's Avatar
no ecu swap, you just convert your Y7 3-wire Iacv to the work with the 2-wire y8 iacv. At the ecu on plug A, move the pin from A14 to the empty slot A12. Remove the pin from A13 and leave it hanging, it is not longer needed. At the IACV, you'll need to frin a round style connector. Disregard the Orange wire as it will no longer be used. Connect the yellow/black wire from your old harness and connect to the green/blasck wire on your new IACV plug. Take the black/blue wire from your harness and connect to the black wire on new plug. Then your done
Old 08-16-2005, 12:17 PM
Default Re: d16y8 vs. d16y7 intake (96CivicBoostCoupe)
hey thanks some great info
Old 08-16-2005, 12:18 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">no ecu swap, you just convert your Y7 3-wire Iacv to the work with the 2-wire y8 iacv. At the ecu on plug A, move the pin from A14 to the empty slot A12. Remove the pin from A13 and leave it hanging, it is not longer needed. At the IACV, you'll need to frin a round style connector. Disregard the Orange wire as it will no longer be used. Connect the yellow/black wire from your old harness and connect to the green/blasck wire on your new IACV plug. Take the black/blue wire from your harness and connect to the black wire on new plug. Then your done</TD></TR></TABLE>
Won't work you will throw a cel because the y7 ecu looks for a 3-wire iacv. That method only works if you convert to a p2p or p28 etc ecu while doing a mini me. You re use your y7 throttle body on an auto y8 manifold or on a 5spd manifold and seal the iacv holes on the back. You also have to change the throttle rotor from the y7 throttle body and put a y8 one on.
Old 09-16-2005, 08:55 AM
tol3's Avatar
Default Re: d16y8 vs. d16y7 intake (chowmien)
What I did on mine i just use my Y7 TB since it essentially very similar to the one on Y8.
marissio
19
09-22-2004 07:04 PM
civic4door95
04-11-2004 08:33 PM
Rhythm Racer
10
10-01-2003 08:35 PM
Shocka1998LX
07-07-2003 09:22 PM
Quick Reply: d16y8 vs. d16y7 intake
