Question: wiring a 97 H22A4 into 97 EK Civic Coupe
I have the engine, trans, axles, mounts, and linkages (everything) installed -- I need some help on the wiring.....can anyone help me out?
Re: Question: wiring a 97 H22A4 into 97 EK Civic Coupe (powerslide360)
I have all the pieces installed -- I need a diagram or info on wiring the engine up -- from the ECU to the engine to make it go vroom vroom and work correctly!!!
Can anyone help me out here? does anyone know how to wire this up? I searched for a thread on the "H22 wiring" but I dont know if the earlier gen H22 engine wiring into an EG civic is the same as an H22A4 into an EK......please help, need to finish!
WTF? what info am I leaving out? The ENGINE is from a 97 Prelude (H22A4) (OBD2) -- I swapped the engine into a 97 Civic (ek) DX model coupe (OBD2). I have all of the major components installed already: engine, trans, shift linkages, axles, mounts, etc.
What I need now, is a wiring diagram to wire the H22 into the civic and make it run properly. If anyone can help me out here, I would appreciate it.
so what harness are u using then? u have an obd2a cuz ur car is 97 so whats the problem? use the harness that came with the motor or use a 96-98 EX harness since ur car is a 97 so that everything runs right.
also theres a difference with the obd2. 96-98 civic is obd2-A. 99-00 civics is obd2-B. find out what obd2 the h22 is.
You just need to extend the wires to the locations. All of your questions can be answered in the FAQ, just read through it. If you need help PM me.
stewartcannon
36
10-24-2015 03:30 AM
Anthony_76
07-26-2013 06:34 PM
ImprtTuner88
01-31-2004 08:35 AM
